Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - file fit rings or std. rings
Old 03-19-2006, 07:04 AM
dboyett38666's Avatar
dboyett38666 dboyett38666 is offline
Originally Posted by NAIRB
If your cylinders are questionable in terms of roundess or straightness, I would use hastings piston rings. Do you know what grit they finished your cylinder with?
Not sure I will ask,and find out.Will the local part store have them,or will I have to go through jegs?Before I put the engine in I am going to do a compression test.I was told it would be fine,but I have never built a motor that had more clearance at the bottom.The bore suppose to be 4.185,and its 4.187 at the bottom 4 1/2 inches on one of the cylinders,but all the other are perfect.
