Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - file fit rings or std. rings
Old 03-19-2006, 08:35 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
Originally Posted by dboyett38666
Thanks I'll use the standard end gap,its much easier that way.I had another post about the 400 block I am building.It has 3 thousands more clearance at the bottom of the cylinder hope its all-right
Are you the same guy that had this 400 block to 2 different machine shops because the first shop screwed up the bore job? Then took it to a another shop to have it fixed? Now the bore is .003 too big at the bottom? If this is a fresh motor and just been bored it is screwed up. We bore blocks all the time and it runs out about .0002 top to bottom. .003 is way off as far as I am concerned.
