Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - file fit rings or std. rings
Old 03-19-2006, 10:15 AM
dboyett38666's Avatar
dboyett38666 dboyett38666 is offline
Originally Posted by RPM
Are you the same guy that had this 400 block to 2 different machine shops because the first shop screwed up the bore job? Then took it to a another shop to have it fixed? Now the bore is .003 too big at the bottom? If this is a fresh motor and just been bored it is screwed up. We bore blocks all the time and it runs out about .0002 top to bottom. .003 is way off as far as I am concerned.
Yea thats me,but I believe its to far at the bottom of the block to hurt,and I know it want touch the rings,and I seen blocks that have been clearanced up to as far as the low spot is in the cylinder for stroker engines,but if it is I'm sure I will find out the first pass,or the first time it cranks,and believe me I will post,and let everyone know.
