fill 34 ford sedan roof - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2006, 08:11 AM
As with a lot of you I have a 1934 fordor sedan.
I want to fill my roof.
What works best for this car?
Thanks
Old 03-19-2006, 09:28 AM
55-57 Chevy roofs are a near perfect fit, but it is criminal to cut one of those up as a donor these days. Unless of course if you found a wrecked one with a good top skin.
We used a late 80's / early 90s Chevy Caprice top on ours. It worked out good, but is not as stiff as I would like. If you want ribs, just about any van top would work. As for flats, station wagon tops seem to work well. Since the '34 top has only a small crown in it, your options are really open. You might just have to english wheel the donor skin a little to achieve the desired product.
Steves Auto restoration also builds new steel inserts for 32-34 coupes. You might give them a call and see if they can roll you one for your sedan. http://www.stevesautorestorations.com/
Best of luck!
Old 03-19-2006, 10:33 AM
Wiki Edits: 49
A lot of people use a ribbed roof from late 50's to mid 60's station wagons. Really looks cool.
Old 03-21-2006, 04:17 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
You could build one.
Old 03-21-2006, 04:34 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
You know, you can buy 18 gauge CRS fairly reasonable these days (I buy a 4' X 10' for under $90.00 (I've heard of cheaper). I'll bet if you went on Metalmeet.com that someone there is in MN. and could E-Wheel it out pretty quick (I'm o.k. on my wheel, probably would take me 3-4 hours-I'll bet some guys there are a lot quicker), and then you would have all new, custom fit Sheet Metal for under $300.00(maybe cheaper if you buy the Beer )-just a thought.
Old 03-21-2006, 05:01 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I used a 40 dollar piece of sheet metal ( about a sixteenth of an inch thick) for my coupe. inch thick. To get the slight crown I layed the metal on the floor with a two by four under each side, then placed a oxygen bottle flat on its side in the center and rolled it back and forth a little. Poor boys have poor boys ways, Lmao.
Old 03-21-2006, 05:40 PM
I helped Randy do a roof for a 30 Model A sedan with his big e-wheel. Took about four or five hours with three - four other guys helping. The roof looked awesome when it was done. Very smooth and metal finished.
wanted frame spec's for a 34 ford 3window coupe wogi 34 General Rodding Tech 3 12-19-2007 08:15 AM
Physical radiator size on a 34 Ford? staleg General Rodding Tech 8 03-10-2006 12:18 AM
34 Ford Side hood grille/vent? Pilot34Coupe Body - Exterior 5 02-28-2003 07:15 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
fill roof in 34 chev duckman Body - Exterior 6 03-22-2002 07:35 AM
