Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Filler after 2K primer question
Old 11-15-2005, 06:04 AM
rcm800 rcm800 is offline
Here is where I am at. I have applied epoxy primer on my bronco. I have then done some small repairs with evercoat Gold and glaze and then I reapplied epoxy over that. I am pretty sure that I have all my panels straight. I am ready to spray my 2K urethane primer on it for block sanding. My questions is that if I find out that I have a problem while block sanding, how do I go about reapplying filler and/or glazing to fix. Do I have to completely sand down the 2K and apply filler? If I do how would I be able to get a smooth edge from the old to the new 2K primer. I also have a couple of small pinholes in my filler work. Should I fill these with glaze before the 2K? I assume that the 2K would not fill these holes right?
Just a little confused about the filler after 2K. Can filler and/or glaze go over the 2K?
