Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Filler after 2K primer question
Old 11-15-2005, 10:27 AM
rcm800 rcm800 is offline
I am using Nason products. Yes my questions was if I needed filler after block sanding the 2K. Should I sand the 2K completely off or scuff and add filler, sand and recoat with 2K. I am also using Nason epoxy. I cannot find in the tech sheet about topcaoting it. I assume that I need to either sand or scuff with scotchbright before topcoating. Anyone know for sure?
