Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Filler after 2K primer question
Old 11-15-2005, 12:42 PM
Bee4Me's Avatar
Bee4Me Bee4Me is offline
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I use Ful-poxy and I will sand or red scotch pad it after 24 hr just to be safe.
I was trying to save you a step without doing much filler over the 2K.
You can guide and block the epoxy real close BEFORE applying 2K, That way, You should be all set to just block the 2K and shoot it.
Light spot filler is fine with a light sand then primer over it with a 24 hr wait after primer for proper cure as BK stated.
