filler for bumper dents&dings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2013, 11:48 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Hey fellas backed into a tree in my daily driver its a 2nd gen ram..the bumper pushed into the panel&crusehed it..I was able to work it out&now its ready for filler.The thing is the chrome bumper..well not even sure if its chrome hit it with the angle grinder to clean it up still looks chrome..guessing its stainless..well anyways I worked most of the damage out with dollys&hammers as the stud welder wouldn't bite to it.What can I use for filler on this to smooth it out?I'm sure bondo will just fall out.It dosnt need much just enough to smooth it out.HELP!
Old 03-12-2013, 12:00 AM
zmaxmotorsports's Avatar
Are you going to paint it,How about lead?
Old 03-12-2013, 12:03 AM
two cups of tea
Wiki Edits: 2
Yes I'm painting it but I need something that spreads like bondo.
Old 03-12-2013, 12:13 AM
Lead isn't that hard to work with,it would be a lot stronger/permanent fix on something that takes a beating like a bumper does
Old 03-12-2013, 04:54 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
You could spray some epoxy primer on it first,
then any filler should bond.
I'd recommend something like Duraglass first
if you're worried about strength.
Old 03-12-2013, 06:46 PM
Just for the meaness of it. Is it aluminum? You say the pin spotter won't weld to it (it will weld to stainless).
Why not just metal finish it and polish it? If it's aluminum, Lead won't stick.
What I do on airplanes is to sand with 220, and use UPol Monarch, or Dolphin glaze.
After acid etch, and alodine. It holds up to more punishment than a bumper will ever see (short of being in a wreck).
Old 03-12-2013, 10:25 PM
Yeah I guess I didn't think about an aluminum bumper on a truck
having an issue with filler (small dents) taylorb2053 Body - Exterior 11 10-20-2011 02:38 PM
w&g remover on filler Nastynotch347 Body - Exterior 3 05-01-2011 08:52 PM
Where to find (or how to fabricate) '80-'81 full size Pontiac bumper filler panels? 81RocketBonneville Body - Exterior 2 07-30-2010 04:13 PM
Body Filler do's & don'ts Ron M Body - Exterior 2 09-07-2004 05:00 AM
Bodylines & filler nationsfinestra Body - Exterior 3 04-07-2003 01:06 PM
