Filler/glaze over epoxy wait time - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 02:06 PM
blacklabzeke's Avatar
I sprayed two coats of epoxy primer and need to know what the wait time is before applying filler and/or glaze. Should the epoxy be sanded before applying filler and/or glaze if within the epoxy recoat time?
Old 09-18-2006, 03:42 PM
adtkart@aol.com
You did not say what brand of Epoxy you used. I use SPI, and I wait until the next day before applying filler. You don't need to sand the epoxy before the filler with that. You might want to check the tech sheet for that brand.
Aaron
Old 09-18-2006, 03:46 PM
I used PPG MP170 2 part Epoxy. The tech sheet does not have any specifics on filler, just recoat time (3 days).
Old 09-18-2006, 03:51 PM
Most epoxies will let you spread filler over them after an hour under normal temperatures (75+) and anything over the hour mark is great with the very best time being letting set over night.
If it were me I would love to see a four hour wait anyways.
Time is on YOUR side!
Old 09-18-2006, 04:11 PM
So I do not need to do any sanding as long as I am within the recoat window (72 hours)?
Old 09-18-2006, 04:29 PM
NO but if that bothers you just hand scuff with 180.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Epoxy primer drying time ? jcarter Body - Exterior 1 12-10-2005 08:21 PM
epoxy prime 1 pannel at a time montea Body - Exterior 3 08-24-2004 04:17 AM
when to topcoat after epoxy primer? brauler73 Body - Exterior 0 09-01-2003 11:48 PM
got time andybird Hotrodders Site Suggestions and Help 1 07-14-2003 02:26 PM
