Originally Posted by turbo t
there is quite a lot of filler i thought it was the primer that shrinks as it pulls into the filler or may i be wrong?
You're right Turbo, the primer is the leading cause for shrinkage. People pile it on to make up for imperfections in the filler. Pin holes, scraches, waves in the filler can't be corrected with primer. Well, except for polyester primer. Polyester primer is basically like spraying polyester putty or body filler. It is literally the same stuff, but sprayable.
It is not going to shrink, if applied correctly. Don't pile it on, apply a three or four coats and you will have plenty to block to perfection. Then apply a urethane primer over that and then sand that with your 600 or 800 prior to paint.
There are other ways, sure, but this is a standard of the industry. You could apply the paint right over the polyester, but polyester is so much harder to sand that it is common to miss coarse scratches with the later finer prior to paint sanding. So to use the polyester primer to block with 180 and then prime it with a good urethane and use the urethane as your base for paint is ideal. Yes, you could use a good epoxy for the final prime as well. I prefer the urethane, much easier to sand.
