3M's 8115, 8116 etc. don't have an adhesion problem with filler. These products, if I am correct, are labeled "Panel Bond Adhesive" and are used for installing quarter panels, door skins, even the roof on cars. I have used filler over top many times and not had an adhesion issue. The issue I have had is the junction line coming back after paint especially if fiberglass is used instead of filler. To help minimize this reaction allow extra time for the Panel Bond Adhesive to cure, depending on what you use, 8115 or 8116, they have different cure times. Just give them an extra few hours...like maybe 6 hours extra time for insurance. I have used Rage Gold with excellent results, finish your filler extra fine (I finish mine in 320 grit) and Prime with a 2 part catalyzed primer. Ensure proper flash times are allowed between coats (and then give it another 5 to 10 minutes, just for even more insurance). Block sand and paint....you now have an invisible repair.
All the best Ray |
| The Following User Says Thank You to 69 widetrack For This Useful Post: | ||
Trucknut (10-29-2012) | ||
I'd use an adhesive repair that's ok for fiberglass and SMC repairs. 3M's 8243 works well for this. If you groove it out nice you can lay a nice bed of this stuff and top coat with a flexible filler like an Evercoat Polyflex. The concern with this repair is differing expansion and contraction rates so if you use the right products you don't have lines showing up or anything. I wouldn't use a poly primer for the hood but a urethane 2k with flex additive would be ideal, but the 2K urethanes have a tad of flex by themselves.
Incredible...You got the wrong guy at 3M. I used to do seminars with a local 3M rep specifically regarding this type of application and that was over 10 years ago. I think if it worked then it will work now...I've said it before and I'll say it again..."Life is the easiest thing you will ever go through, it's only people that get in the way".
cc82z-28 (10-31-2012) | ||
Good luck with your project. The products that you have used will work fine...I would have recommended that exact product to you even prior to your posting.
Best to you Ray |
| body filler question | cooltc2004 | Body - Exterior | 2 | 01-31-2012 05:52 AM |
| filler question | jasrking | Body - Exterior | 1 | 06-13-2008 07:39 AM |
| metal filler question | mr52pickup | Body - Exterior | 1 | 07-10-2006 08:12 AM |
| question about guidecoating and filler | Dubz | Body - Exterior | 3 | 11-03-2004 10:12 PM |
| Got a filler question here | Bluepen | Body - Exterior | 2 | 04-18-2003 04:40 PM |
