Filler temperature - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2004, 06:49 PM
New Member
Filler temperature
I am working in a garage in NE Ohio. The furnace stays at 50F, except when I am working and I turn it up to 60F. Can I apply filler in this climate? The filler I am using is Evercoat Rage. It says the setting time is 5-6 minutes @ 75F to 80F. Any help would be greatly appreciated.
Thanks
Old 12-16-2004, 09:19 PM
Do a few test panels to get the amount of hardener needed, it will cure.
Old 12-17-2004, 08:08 AM
New Member
Thanks MARTINSR. You are always there when us rookies are in a bind.
Old 12-18-2004, 08:51 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
I've done a lot of boat repair with the 3M marine filler (very similar stuff) and it does OK to about 55 degrees in my experiments. I'd be worried going much colder.
