Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Filler tube leak
Old 10-08-2003, 12:05 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
I`ve never seen a GM tranny without the O ring, however, I`m sure you can go to any parts store and get the correct O ring, or swipe it off another tranny, I wouldn`t use the gasket sealer, as most of the O rings on the dip sticks are fairly thick and you would have to clean it all out to get the right O ring back in, seems to me as if it would be easier just to get the O ring and do it right the first go round so you don`t have to go back and do it later.
