-   -   Filler tube leak (http://www.hotrodders.com/forum/filler-tube-leak-25210.html)
Deadtemple 10-07-2003 01:06 PM
Filler tube leak
When I pulled out the filler tube on my 200r4 tranny it was very difficult to get it out.
Now I can not get it to tighten up. There is no O-ring for it to fit into. Do you think it would be best to get another filler tube and O- ring, or would gasket sealer work?
This is only a temporary tranny, till I get the money up to sup-up the car.
DoubleVision 10-07-2003 11:05 PM
I`ve never seen a GM tranny without the O ring, however, I`m sure you can go to any parts store and get the correct O ring, or swipe it off another tranny, I wouldn`t use the gasket sealer, as most of the O rings on the dip sticks are fairly thick and you would have to clean it all out to get the right O ring back in, seems to me as if it would be easier just to get the O ring and do it right the first go round so you don`t have to go back and do it later.
airworld2 10-08-2003 06:39 AM
filler tube leak
see your local tranny shop or dealer and maybe parts store ask for an filler tube boot or top hat (black rubber sleeve looks like top hat) it replaced the old style o-ring on tube change was made on 1980 and up gm tranny, now most trans use this style fill tube less leaks
