filler on valve covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2011, 04:53 PM
Last journal entry: Body work
I have a set of aluminum valve covers for my lt1 350 that I would like to paint but the castings are pretty wavy so, I would like to fill them.
I'm not sure body filler would tolerate the heat though.
I should also mention that this motor has twin turbos and they are rather close to the valve covers too.
Any suggestions?
Old 12-28-2011, 06:09 PM
Any suggestions?
I am thinking you may want to "cut" them flat (grinding most likely) so they don't need any filler. Filler on engine sheetmetal is usually not a problem at all though. But with your turbos.......I am not so sure.
Old 12-28-2011, 06:14 PM
BOBCRMAN@aol.com's Avatar
I use a product called "All Metal'" when powder coating parts. Holds up to high bake heat
« Bumpers | painting »
SBC Valve Covers w/o Filler Cap lt1silverhawk Engine 17 07-07-2011 05:53 PM
Valve Covers dmbolf Engine 5 10-02-2010 01:37 PM
valve covers 3dhunt Engine 1 12-09-2003 06:53 PM
Valve Covers comet boy General Rodding Tech 2 11-01-2003 11:39 AM
Valve Covers Thacolbster Engine 11 02-07-2003 05:15 PM
