filler visible under epoxy primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2009, 06:48 AM
I'm doing my first paint job and I just sprayed epoxy primer over bare metal and filler work. My intention is to sand and then spray polyester primer over the epoxy to perfect the body work. My concern is that after two coats of epoxy, I can still see the areas of body filler underneath. The filler is covered well enough but it's like it has a different texture and shade than the areas that were bare metal. Is this normal or have I done something wrong? Will everything look consistant once the polyester is on?
Thanks!
Chris
Old 07-10-2009, 07:54 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
it's normal. the metal is smooth and the filler was sanded.
Old 07-10-2009, 08:19 AM
Yep, it's normal. That is what the polyester primer is for, to level out all the imperfections. You may even see them in the polyester primer....BEFORE you block it, at that time any small imperfections will be gone.
Old 07-10-2009, 10:35 AM
shine's Avatar
SPI Thug
i no longer use polyester primer. i just continue with the epoxy until i'm satisfied with it then paint.
Old 07-10-2009, 11:56 AM
deadbodyman's Avatar
Wiki Edits: 11
same here.... no need for 2k.... bondo absorbs and metal dont,just sand and reshoot
Old 07-10-2009, 01:33 PM
wildthing's Avatar
Last journal entry: 95 % done
yep mine looked like that too , until i shot the 2k primer over it.
Old 07-10-2009, 02:48 PM
Thanks for all the replys! I feel totally relieved to hear it's normal. Now I'm not sure what to do. I already bought the 2k, but you guys think I'm better off sticking with epoxy. I guess I'll decide after sanding. Thanks again for the help!!!
Old 07-10-2009, 03:09 PM
Wiki Edits: 11
not necessarily CK,the epoxy shine and I use is SPI ,the others I've used cant do this so go and use the 2k ,it works well also ,but sand the epoxy first,mabee with 180 or so,to give that 2k something to bite into but not so rough as to get down to the metal as 80 grit would
Old 07-10-2009, 04:08 PM
Irelands child's Avatar
The SPI sands nicely, almost as well as the 2K - up to a point and that being several weeks after application when it really gets hard. You can still sand it then, but it just becomes more difficult. DuPont/Nason - let it sit a few days - and you will never sand it like the SPI - ever. I ran out of SPI and used some DuPont to cover some bare metal, had to let sit for a couple of weeks and then had my "fun". Scuffed with 180 then did 2 coats with my fresh order of SPI, wet sanded the next day with 600/800/1000 then painted on the third day.
Poly primer - not really nice stuff to work with IMHO though I had to use some on the trunk lid of my '31. It works well for those less then perfect panels that need just a bit more TLC
Irelands child
Having problem with epoxy primer...... onebadmerc Body - Exterior 22 05-19-2011 02:31 PM
Self Etching or Epoxy Primer Ron M Body - Exterior 14 11-30-2010 07:23 AM
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 06:50 PM
Epoxy Primer - Questions S10 Racer Body - Exterior 1 06-23-2008 08:06 PM
Body Filler Over Epoxy primer lowlife_caddy Body - Exterior 4 08-26-2004 05:14 AM
