Filling Hole in Fender - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2011, 01:05 PM
Whiskyb's Avatar
I have decided that I do not want to use my original fuel door/flap. I need to fill this in before I paint. The fender is fiberglass. What would the strongest way be to smooth this over and not have it show the seam/joint
Old 08-03-2011, 04:50 PM
milo's Avatar
point on positive
When you set the fuel door in there how big is the gap going around it?
Thinking you could create a rest stop in the opening to position the door maybe 16th of an inch lower than flush first.
Then remove some material 3 inches around the opening on the fender to allow room for using a OnetoOne epoxy resin and glass cloth across everything and finish it off with a little filler etc.
Key will be to do it in steps and the right resin to bond to already cured glass.
Old 08-03-2011, 06:27 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I would cut the gas filler area off. Then grind both side good and taper the edges and build up both sides with resin and glass mat. and finish with bondo and work from there.
Old 08-04-2011, 09:32 AM
Whiskyb's Avatar
Thanks for the advice. I am still kinda mad at myself for not ordering the fender without the fuel access and now must deal with it. If I don't I will never be satisfied
Old 08-04-2011, 04:55 PM
dinger's Avatar
I would do this the same way but would try to use the door.
Off topic, but what is your avatar? Very interesting, cool art.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 08-04-2011, 05:40 PM
Whiskyb's Avatar
Not sure what my avatar is but it is definitely me! I found it on google images and have used it for years. I even have a version being painted on my garage wall.
2 hole exhaust flange connecting to a 3 hole JLBpontiac350 Engine 0 04-26-2011 02:31 AM
Cracked steam hole going to bolt hole projectman69 Engine 4 11-10-2010 07:54 AM
Filling the floor hole 1930u Body - Exterior 7 01-16-2008 12:48 AM
Tire Cover as Fender?(cycle fender), Need Bracket Ideas! Fred A Body - Exterior 1 01-29-2006 03:46 PM
37-39 rear fender welt/ fender repair? jcarter Body - Exterior 8 02-17-2004 08:41 PM
