Martin, LMBO, as much as I would dislike the "chicken", if it was well done, making the paint score higher (quality, quantity, and degree of difficulty) then it would win.
unstable, actually some of those cars have had $500,000.00 spent on them. Sometimes it comes down to those hidden details that win. At those type of shows every thing has to be on paper (judging sheets) tallied and re tallied. The judges are paid several thousand dollars each to work those shows, if they are not good judges then they don't do many shows. I'm not saying that all shows are judged that way. Certainly your outdoor neighborhood shows are not. Most things that can be done to a car have already been done, it comes down to who can do them the best. And when something new is down to individualize a car, then certainly that would weigh heavily with the judges. It should come done to who did what they did the best ( detail ). Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
back to the point. use "bolt on" electrical knock out seals to fill the holes and weld them in. there are many sizes that are a perfect fit for the holes in my 55 chevy truck's firewall. made life alot easier. also when i filled the gas filler hole in the side. i used one that was a perfect fit. covered with some bondo.
want goofey cars? www.burningman.com as far as painted engine compartments, i love them over black. stock is always black. and my paint shop wants a whole lot more to paint it. i really wanted my camaro;s to be painted cause i had the engine out. but i would have had to tow it there. it was more pain intheass than it was worth. i've seen nice cars as well with black engine bays so.... |
if you're going to use bondo either way...I personally wouldn't worry about the warpage too much. Make the patches the same size as the holes, or as close as you can get them, tack them in, working in a circle doing "blips". Keep working until it's all the way in, grind smooth, hit with bondo.
I'd be interested to know what guys like Randy would do for this...because doing metal finishing on an in-tact firewall would be difficult without a helper...probably even with a helper. |
Don't think for a second that 16 guage won't warp, heck you can warp a FRAME if you weld it incorrectly. You still have to manage the heat and be very careful.
Being the fire wall has lots of body lines to keep the rigidity and is 16 guage, you are right, there is a lot less of a chance of warpage, but it can warp. If you really wanted to cut to the chase and not weld, Bonding a patch on the back with a panel bonding adhesive would be as good as it gets. Cut a patch an inch or so larger than the hole, grind the back of the hole with 36 grit, grind the patch so those ground areas meet when you stick the thing up there. Apply a quality Bonding adhesive like 3M's 08115 and after curing grind off the excess. Apply a coat of Evercoat's "Everglass" over the area and a skim coat of polyester putty and your done. Welding is ALWAYS the perfered way, but not everyone has a welder or the skills. A qualtiy bonded on patch is a close second to welding. |
yeah it WILL warp, but that can be worked out with hammer/dolly and helper (i'd imagine).
BUT, if you're throwing filler over it either way...I wouldn't worry about the shrinkage too much...as long as you don't get crazy with the welder and try to make a pool of molten metal. |
Firewall
Guys -
While we're on the subject of firewlls: A while back I asked about battery mounts and didn't really get what I needed although I did get some ideas. What I would like to find is a trick battery mount (billet aluminum, chrome, etc.) to mount on the firewall. If anyone knows about a stock shelf-type battery mount let me know because I could buy it from the dealer and have it chromed. Otherwise I could go through a junkyard and look for a mount that would work. Any suggestions? Charlie Smith |
I know that the 55-59 Chevy Trucks have a shelf-type battery for firewall mounting. You can get them from http://www.brotherstrucks.com or any early model parts place.
Re: Firewall
At unstables request, Here goes!! (Not that y'all will like my opinion.) Perhaps I've mentioned this before, but I HATE bondo!!
The nasty junk is the very reason I first wanted to learn to shape metal and to finish it without the use of filler. I ain't sayin' you can learn it overnight, but it really isn't that hard once you figure out the few simple rules. Welding of any type caused shrinkage in the heat affected zone, which shows up further into to panel as warpage. Not to fret though, as the only problem spot is within the blued area, which is known as the heat affected zone, or HAZ. By simply placing a dolly on the backside, (with a crown very close to that of the panel being worked) and a very low crown hammer, or better yet, a slapper, on the face side, work the HAZ by stretching the metal back to it's original condition. On a firewall, a helper would be a must, as your arms aren't long enough to reach inside the car to hold the dolly while working the opposite side. Once the metal had stretched to point of meeting it's former condition, all warpage will be gone and there will be no need for filler. To fill the holes in the firewall, circles will need to be cut, or find a proper size plug of the right thickness and have at it. If you're lucky, and you probably will be, you can finish this off like a real pro. Learning to finish welds properly only takes a little time. There are no real tricks to it. It just takes patience. Something like filling firewall holes can be done just as fast by metalfinishing than screwing around with filler. Not to mention, it's far superior. Randy Ferguson Metalshaping & Kustom Paint www.metalmeet.com |
![]() Keep beating on us to do better but allow us to Bondo occasionally until we approach your fantastic skill level. |
Willy's,
that's precisely the approach I'm taking. I want to be able to finish metal perfectly without bondo...but it does take practice. I figure, if my attempts at finishing allow me to use less bondo...then I'm doing good. |
I was amazed when American Rodder came on the air to see that Coddington's 'expert' builders use Bondo by the gallon. Perfect metal finishing is a great goal to shoot for but for us part time amateurs, won't probably ever get there. Bondo is a great compromise.
