Filling holes in sheet medal questions? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-09-2003, 04:27 PM
Mav's Avatar
Mav Mav is offline
Post
I know its not too popular these days with the health hazzard but i would give lead a shot .... If you follow the standard safety precautions you should be fine ... I did whe whole left side of my car with lead (34 holes)in less than half a day ... Theres a great article in carcraft.com about using lead http://www.carcraft.com/howto/3065/
I know that there are a lot of great fillers out there today that are just as good or better then lead but for me its just so much better knowing theres no " Bondo " on it ...
  #17 (permalink)
Old 05-09-2003, 06:53 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Post
Saw a guy on a show called "A Car is Reborn" do a lead job on a XKE. Man when he was done you could not tell at all where they had patched the fender area. Looked kinda easy he welded a patch in from the back and then over filled the area with lead. Then used a rasp to re-shape the area for the rough out then sanded it to make it perfect. When he was done it was truely a work of art! Make sure you us a resperator with the proper filters and gloves and all will be fine.
Regards
Mark
[ May 09, 2003: Message edited by: Jag Daddy ]</p>
  #18 (permalink)
Old 05-10-2003, 01:48 PM
adtkart@aol.com
Post
WOW! Talk about some different ideas! I had read somewhere about some kind of "copper backer" to use when welding holes. I was trying to figure out a way to make one. Holding a penny just didn't seem comfortable to me. The pipe idea does sound better. The copper will help keep the heat on the panel down, as it works as a heat sink. Also in areas where the appearance of the back side isn't important, I have used steel washers or scrap. The only thing about that is that you need to make sure that it is treated with something to restrict corrosion. Welding promotes that.
  #19 (permalink)
Old 05-10-2003, 05:09 PM
Mav's Avatar
Mav Mav is offline
Post
adtkart ... Read the article from the link i posted .... They suggested using aluminum tape ... I did the same thing ... OMG it was so easy !!!!! The first few holes took a little longer but once i got the hang of it the rest was a breeze .... I am now a "lead Head" Whats best about using lead is that i used a propane torch from home depot !!!! Very little heat and it looks like part of the car ....
  #20 (permalink)
Old 05-11-2003, 12:14 AM
black66's Avatar
www.airriderz.com
Post
I have found anytime you have to weld, grind or use a "flapper" sanding disc on automotive sheet metal you should quench the steel with water. It helps shrink the steel and keep warpage to a minimum.
  #21 (permalink)
Old 05-11-2003, 03:18 AM
Question
THIS IS MY FIRST POST,BEAR WITH ME. ON THE NET I FOUND A PARTY THAT ADVERTISED A THING CALLED A SPRAY WELDER. THEY WANTED TO SET ME UP IN A FRANCISE. NOBODY I TALK TO KNOWS ABOUT SUCH A THING. THEY CLAIM THAT THE WELDER FILLS THE HOLE WITH METAL AT 110 DEGREES. IS THIS TOO GOOD TO BE TRUE????
  #22 (permalink)
Old 05-13-2003, 04:49 AM
pappy 32's Avatar
Last journal entry: Heading home
Post
I use brass as a backing for a mig fix. You can mend a fairly good size hole. You can make a tail from the outer side of thr hole and then fill from the center out. It's tough to hammed for sure, but using low heat (propane torch) you can file easy or grind with a higher grit wheel. One thig to consider on location of the hole, if it is located where there will be flexing of the metal you could end up with a cracking problem. That's where the leading is a good idea.
  #23 (permalink)
Old 05-15-2003, 02:59 AM
Post
Make sure the metal around the hole isn't thin, you might as well replace it now rather than filling holes continuously over time. Also, if welding the floor inside make sure the sparks are sheilded from interior jute matting or anything burnable. Sheilds can be made from scraps of thin steel or aluminum which bends easily and can conform more to the working area. Good luck!
  #24 (permalink)
Old 05-18-2003, 07:59 PM
Talking
40 Chevytrucker, I called the company about the spray welder and they were suppose to send info.
Been about a week and still no info . This thing sounds too good to be true. Did you get a quote on the cost of the welder? Must be expensive cause they advertise you can own one for 600.00 a month. Sounds too much like a car payment or better yet a house payment. Thanks darin
  #25 (permalink)
Old 05-19-2003, 04:42 PM
adtkart@aol.com
Post
Mav... I was impressed with all of the other ideas of ways to repair holes, not the "LEAD". I have been around automobiles since they used lead regularly. With all of the other health hazards working on cars, I see no real advantage of using lead. When you go to sanding, gloves and a respirator are not really enough. The dust can enter your system through your skin anywhere on your body. You made a statement about knowing that there is no "bondo" in it. Unless you have stripped it down to the bare metal, you can't be sure of that. Any car with a welded quarterpanel has some body filler of some type in it. One problem we also saw regularly with the use of lead, was corrosion in the repair area. That is something else to consider.
  #26 (permalink)
Old 05-21-2003, 10:04 PM
Post
Everyone seems to have their own way that works but for me i find leaving a thin gap around the patch allows for expantion while your welding.I like to weld as cold as possible and grind the head off as soon as possible. Thus your grinding off very hot metal and getting rid of heat which warps sheetmetal. I also let it cool on its own. Cooling it fast shrinks the metal and also makes it hard. If your welding a lot of holes take your time and let the metal cool to room temperature before going on to the next one. Go to the other end of the panel and do another while you wait for the other one to cool and so on.The key is patience and keep the panel cool.
  #27 (permalink)
Old 06-27-2004, 10:04 PM
Roadsire's Avatar
Last journal entry: Dash mods
On small holes I use a piece of copper old pipe flattened out and hold behind the hole and mig weld as the steel will not stick to the copper and helps prevent burn through on the lagerones say a 1/4' I work the outside edges and fill the center grind and use filler if needed and move on good luck nice truck by the way I just got a 54 that has its share of metal work that will be needed
