Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 02-17-2005, 08:01 PM
35 Buick 35 Buick is offline
Filling the roof
I am building my first street rod. I have built muscle cars before but this is the first rod. Anyway, it is a 35 buick and I have transplanted a power sunroof top into the open top of the car. My question is should I weld this thing in solid all the way around? Also the original top has small rectangles all the way around where the nails went through. Should I weld all of these up? I was thinking it might be better to stich weld the top and leave the rectangles open so the filler can squish through and grab a hold. What do you experienced guys think?
Old 02-17-2005, 08:08 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: Filling the roof
It has been my experience that it is better to weld the piece in solid. Any gaps or opening do let the filler get a good bite, but, on a roof, there is a lot of seasonal heat changes and the filler will either show up badly and/or crack anywhere it is not supported by welded sheetmetal.
Old 02-17-2005, 08:15 PM
Thanks, I'll need to buy 50 lbs of wire. This car is a four door sedan and has 4 acres of roof. I was thinking I should probably use tiger hair filler for more strength on the roof.
Old 02-18-2005, 02:14 PM
baddbob's Avatar
baddbob baddbob is offline
If you're going to use filler on the roof the seams will definately need to be completely welded, otherwise the expansion and contraction will crack your filler. Get your metal work as close to perfect as possible. Try to keep your filler to a minimum and apply two to three good coats of epoxy to the bare steel before applying your filler.
Old 02-18-2005, 02:24 PM
BarryK BarryK is offline
Great idea, the epoxy will make the fiberglass or body filler more flexible and less likely to pop lose or bubble from contraction and expansion.
Old 02-18-2005, 03:56 PM
What epoxy do you recommend?
Old 02-18-2005, 08:42 PM
baddbob's Avatar
If you want to save a few bucks and still use a quality epoxy I would suggest using PPG EPX-900 out of the light industrial coatings line. It is nuetral in color but your jobber can tint it any shade of grey if prefered. CRE-CT is another good product but very thick. DP-LF is more expensive but I don't see any benifits. There are many epoxies available these days. Valspar, Matrix, Transtar all offer decent products. Dupont and Akzo Nobel also carry good products. Akzo Nobel's U-tech line of epoxies are very good. Southern Polyurethanes has been brought up on this site as having a good epoxy but I haven't tried the stuff yet.
Just make sure your metal surface is very very clean before applying the primer. After cleaning you should be able to wipe the steel with a dry white paper towel and the towel will remain clean. Allow proper flash time between coats. And let it set a minimum of overnight before applying your filler. I would use Evercoat's Everglass or Glass Lite over your weld areas and anywhere the filler will end up at or near 1/8" thick, then skim it with a thin coat of Rage or Rage Gold or my favorite Rage Extreme. I know I sound like a salesman for Evercoat but I really do like these products- they never fail me. Stock up on sandpaper. Bob
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Filling the roof"
Filling holes on a '56 Mercury roof Slipangle Body - Exterior 5 07-27-2004 06:32 PM
Filling the roof on a Model A? Gleeser Body - Exterior 6 06-03-2004 11:43 AM
28 Ford Tudor Sedan roof filler Marc Connelly Body - Exterior 13 11-27-2003 06:19 AM
the roof! the roof! the roof is on fire! DragLinkscc Hotrodders' Lounge 18 09-20-2002 08:22 AM
filling a model A tudor sedan roof replay88 Body - Exterior 1 07-01-2002 02:57 PM
