Filling top on 34 ford coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2007, 10:21 AM
Last journal entry: 34 Finally
Can anyone give advice to the best way to fill the top on an a 34 Ford coupe. The car has long standing rust issues at the original opening and it makes little sense to repair back to original. I remember reading some time ago that donor cars(ie; station wagon,van) are the best way to get a factory braced and ribbed filler panel. Which donor cars should I seek out? I am hesitant to use unbraced sheet steel. Welding is not a problem here. Thanks
Old 01-28-2007, 10:27 AM
poncho62's Avatar
Wiki Edits: 5
I dont think, that it is so much the ribbed/braced panel, as it is getting the right contour. You want to find a filler panel with the right shape to it to look right.
Ontario Rodders
Old 01-28-2007, 10:47 AM
dinger's Avatar
Ponch is right on. I used a mid 60s Falcon to fill my 36 Ford. The older metal would probably be easier to use. Dan
34 Ford Roadster Top Steve R Body - Exterior 1 10-20-2011 09:35 AM
wanted frame spec's for a 34 ford 3window coupe wogi 34 General Rodding Tech 3 12-19-2007 08:15 AM
ford 35 coupe gunnulf Hotrodding Basics 2 09-19-2005 04:27 PM
steering column for 34 ford coupe jaxhome Suspension - Brakes - Steering 2 09-12-2005 06:59 PM
34 Ford Side hood grille/vent? Pilot34Coupe Body - Exterior 5 02-28-2003 07:15 AM
