Filling trim lines (Model A) - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2008, 12:21 PM
I have some trim lines that I want to fill in that run around the roof line of my '31 Model A. They are about 1/8" deep by 3/4" and have 1/8" holes all the way around. I could weld the holes but it would take weeks so I wanted a filler that I could put in there. The local autobody shop suggested I use Evercoat Poly-Flex:
http://www.evercoat.com/productDetail.aspx?pID=8
I'm reading that this is just for skim coating not build-up, any ideas what I could use or if this will be okay??
Thanks,
Sean
Old 10-24-2008, 05:21 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Are you not going to fill the roof with a full roof panel? Most people that do just have the new panel run over the top of that area and weld the roof on and that covers the holes.
If not, I still think your better off welding up all the holes. It might not take as long as you think. Take a piece of copper water pipe and smash it flat on one end and use that to back up the hole as you weld it up (I'm assuming you have a mig wilder) Once you have the holes sealed up, I would use some fiberglass reinforced filler to rough fill in the trough.
http://www.evercoat.com/productDetail.aspx?pID=38
Then you can go over it with a good quality filler to smooth it out. Make sure you sand the fiberglass filler before adding more, other wise there's no teeth for the coat of regular filler.
If you really want the easy way out tape up the bottom of the holes and just lay the fiberglass filler in there and finish off with regular filler.
Old 10-24-2008, 07:01 PM
Funny you mention the roof panel, I welded one in and spent hours getting it into the convex shape to put the vynel on then just when I thought it was good enough I found a 38x68" sliding rag-top that's going in now. It should take up almost the entire hole, I can't wait to get it on.
I have some fiberglass filler but I didn't think it would work that thick, I'll give it a try. I thought maybe some metal filler or something might be best but I'm no body man.
Here it is so far:
Thanks,
Sean
ID:	33504   Click image for larger version
ID:	33505   Click image for larger version
Model A Factory Tour Pics... moefuzz Hotrodders' Lounge 6 09-16-2010 08:48 PM
Are all Model A chassis the same? HotRodKush General Rodding Tech 12 03-16-2010 08:05 AM
brake lines too short after suspension rebuild FiveFeezy Suspension - Brakes - Steering 4 03-10-2004 09:25 PM
-AN fittings on transmission cooling lines jamnut Transmission - Rearend 3 07-14-2003 11:07 AM
filling a model A tudor sedan roof replay88 Body - Exterior 1 07-01-2002 02:57 PM
