filling a void? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2007, 04:58 PM
37 plymouth coupe's Avatar
filling a void?
The PO of my 37 coupe was a gauge junkie. I have an amp gauge and a volt gauge, a water temp gauge, and oil temp gauge and a transmission temp gauge, all this plus speedo and tach. Since the amp gauge does not work (I relay on the volt gauge) I want to remove it. I need something to fill the hole, so I'm thinking a CLOCK. Any ideas on installing a clock motor (AAA battery powered) into the SW amp gauge? Would like to have a face clock (black background white numbers), but keep the SW label so all gauges still match and illuminate from the dash lights. Anyone ever tried this?
filling up air injection ports. crossy Engine 7 06-13-2006 07:19 AM
Filling in trim holes 5.0Falcon Body - Exterior 10 02-10-2005 09:14 PM
Filling Holes Ron M Body - Exterior 2 09-11-2004 03:04 PM
Filling holes on a '56 Mercury roof Slipangle Body - Exterior 5 07-27-2004 06:32 PM
Filling Block/ Hard Block??? camaroman7d Engine 8 01-15-2004 07:30 AM
