Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Final sealer fixes
Old 09-24-2009, 08:32 PM
bobyell's Avatar
bobyell bobyell is offline
Final sealer fixes
Hi guys,
I have used ppg dp50lf epoxy primer on the parts as the base primer. Once it was sealed I used a primer surfacer to get ride of sanding scratches etc.. When I was satisfied with the look and feel of the panel I put the final ppg seal coat over that. But I noticed that after I applied the final seal coat that some minor spots I missed appeared. Can I just use spot putty on the area and sand then reseal that spot only?
I intend on wet sanding the final seal coat with 600 grit paper to get rid of the minor orange peel.
You guys and this site have help me out a TON on how to paint and diagnose "gun issues" I can now spray with very little peel on the primers.
Bob
