Final two issues on build - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2010, 11:20 PM
NOlowrider's Avatar
US Navy-Retired
Hello guys-
After a very long and stressful build I have come down to two last issues I need to resolve and I would like some input.
1. I installed a high flow water pump and complimented it with a hight flow t-stat (Miloden). The blower manifold does not have any provisions for the by-pass hose for a BBC. So, I planned on drilling a few holes around the t-stat, but after taking a look at it, there is not enough room around the perimeter to drill any holes. Hmmmmmm. So, I guess I will get a regular t-stat and drill and use it. Will it be OK to use a normal flow stat with a hight flow water pump?
2. Timing. Can't decide if I should go with locked out timing (28-32 range) with a 10-15 deg start retard. I do have a BTM, so should I just lock it out and give her as much initial as it want's? Or, set a curve 16-24 deg initial, with a total of 32-36? I have a digital e-curve so it would be easy to set. I just would really like to get it right the first time and not do any damage to my money pit.
One more thing, should I do my first start up without the blower (remove belt) and just to get her running, do a leak check, set timing, ect.?
Thank you for any advice.
Steve
Old 08-28-2010, 11:28 PM
NOlowrider's Avatar
US Navy-Retired
sorry for the double post. Having trouble with my Wi-Fi.
Old 08-29-2010, 06:55 PM
NOlowrider's Avatar
US Navy-Retired
Anyone? Sure would like to get this thing finished.
Thanks F-Bird for the PM regarding the timing.
383 build looking for opinions 48Frankin Engine 13 03-08-2010 05:08 PM
350 vs 383 build for performance Biscuit6447 Hotrodding Basics 20 03-05-2010 08:42 AM
Considering a purchase - Need comment on the build Zeeb Engine 7 03-02-2010 05:53 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
500 stroker build newbie questions? Monster_Magnet Hotrodding Basics 3 07-04-2009 11:41 AM
