is it a brand new welder? what is it set up for now?(drive spools,torch tip, and hose liner) often if the liner is set up for the bigger wire you can run the smaller wire without chaging the hoses liner. you will just need to change the drive spools and torch tip, when you switch wire. but thats just what i would do you can use each wire for both body and chassis |
you should confirm that the only things needed to change is the little wheel and the tip of your handle, in the owners manual or check with your welding supply store if you have to buy other stuff to switch it (spool and tips) i would buy both size wire, because it will be easy to switch (you already have the big wire stuff) |
welding info
Martinsr has posted a lot of good info on Mig Welding here on hotrodders and links to other articles he has written Do a search (Martinsr verticle welding or inverted welding) on this site
I still remember how it felt waaaaaay back when I bought my first set of ox/ace torches ....Your batman.... |
been looking into getting my first mig welder, did some stick welding about 12-13 years ago in shop class, lol, now i am finally gonna take the plunge, i hae a good solid project truck that needs only a little work figure i'll find a used mig on craigslist and get some scrap metal and start practicing, i have seen some good deals just havent been able to get ahold of them in time, im still searching
good welder = good welds, cheap-o bad welder = bad welds |
| Recent Garage - Tools posts with photos |
| bought a new welder | domesticsrule | Hotrodders' Lounge | 1 | 11-09-2008 07:38 PM |
| Finally bought a mig!!! | cruzinTLT | Body - Exterior | 8 | 09-24-2006 09:16 AM |
| I finally bought a paint gun set! | schnitz | Body - Exterior | 12 | 03-22-2006 05:12 AM |
| Finally bought myself a welder :D | Ripped | Body - Exterior | 6 | 11-01-2005 11:37 PM |
| I bought a Welder, Need some info | Malibucdl | Garage - Tools | 28 | 08-13-2004 01:17 AM |
