it finally came together - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2009, 07:48 PM
http://www.youtube.com/watch?v=QC6mLB3zOF8
I have been working on this car for a while and have had many questions answered. thought i would share.
95 nissan 240sx
40 over 350 4bolt 9.3 c/r
crane cam 282 226/226 .470/470 lift 106 lsa
vortec heads
performer rpm intake
750 holley w/ vac secondaries
Old 11-29-2009, 07:55 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sweet that's going to be alot of fun.
Cole
Old 11-29-2009, 09:17 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
that should be easy 12's. My friend did one with a 340 mopar and it took a lot of work to the front suspension to fit. but with a nasty cam and ede rpm heads it went 11's.
btw, those valve covers don't look like they are on vortec heads...
Old 11-29-2009, 10:33 PM
I use an adapter because vortec valve covers are pretty spendy.
It had 331 that had flat tops and was around 11.5 cr til the block froze and cracked. It went 11.7's on 10in slicks but for a grocercy getter and street tires traction will be limited. I plan on putting on spare set of 205/65/15's on the back and seeing if I can break em loose at highway speeds. They say a stock LS1 can break normal tires loose in the top of 4th.
Old 11-30-2009, 06:45 AM
NXS's Avatar
NXS NXS is offline
lol, that's odd b/c my friends car had bad traction problems.
He eventually sput it out (I think it was a shoddy job on the front end myself) and stuck it in a Cuda with more nitrous. It went 10's there is a pic in my album of it, and a video riding in it too. the yellow one. Good luck with that spinning, shouldn't be a problem
Old 11-30-2009, 06:08 PM
both motors are making within 10 hp of each other. the 350 should be around 375 the 331 was 385ish, but the new motor is making WAY more torque.
finally getting back to work on my old truck pancake Introduce Yourself 1 04-10-2009 05:59 AM
Finally Clear! Rat Rod and Ratty Rod!!!! Not A T 25 Hotrodders' Lounge 16 08-31-2007 06:37 PM
Ford 351c Facts Finally Revealed KULTULZ Engine 1 01-10-2007 12:10 PM
Finally Fixed High RPM miss on the S-10 TurboS10 Engine 7 05-24-2005 06:40 PM
Finally Got A Car!! crazygutgut Hotrodders' Lounge 16 04-19-2004 09:39 PM
