Finally landed a Sewing Machine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2013, 05:57 PM
It's a lightly used (from all appearances) Juki LU-563. Had it checked (and oiled according to them), but now I'm stuck.
The manual I downloaded seems to be a very poor pdf of a photocopy of the original manual.
I'd like to oil it before I even consider how to thread it. The diagrams are completely illegible (for a novice, anyway).
Any clues? I will say that there are a bunch of holes with red lining, which I'm willing to bet, are the oiling points, but some are different sizes. How many drops am I supposed to put in them? Is that the reservoir marked "oil" near the needle? How much am I supposed to pour in there?
Then I gotta figure out how to thread the damned thing.
The machine shop gave me #22 oil. The manual doesn't specify, but I assume this will work?
Old 07-22-2013, 06:03 PM
BOBCRMAN@aol.com's Avatar
Try Sewing Machine Manuals, PDF Sewing Machine Manual Parts Books and Instructions
Old 07-22-2013, 06:14 PM
That's just the parts list. I think I'll try downloading it to see if they actually include the instruction manual.
Yeah, it's just the parts manual. No instructions.
Old 07-22-2013, 06:35 PM
Try this http://www.raichert.com/adobe/LU562%20LU563.pdf
Old 07-22-2013, 06:51 PM
Originally Posted by BOBCRMAN@aol.com View Post
It looks like the same file. Any pointers would be appreciated!
Old 07-22-2013, 06:58 PM
Read. Starting at 1 - 12.. Tells how to thread, what to use etc.
Old 07-23-2013, 10:02 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Manual oiling is pretty much common sense, so they don't usually put oiling instructions in the operating manual. First of all, just use any good quality sewing machine oil, which is basically just mineral oil. Do not use 3-in-One oil or any petroleum based oil. If you don't use sewing machine oil, it will gum things up and stain fabrics. Secondly, there should be some red paint on the openings that require regular oiling, and the rule of thumb is the bigger the opening the more oil you use. A small hole only needs a couple drops and the larger openings take more. You don't need to soak it, because you should be doing it regularly. Thirdly, make sure you put some oil along side the bobbin case, and take the end cap off the machine and put oil on the wicks at some of the joints that you see behind it.
If there's a reservoir, then the machine is self oiling and all you need to do is keep it filled to the recommended level.
ID:	75909   Click image for larger version
ID:	75910   Click image for larger version
ID:	75911   Click image for larger version
Old 07-23-2013, 05:06 PM
I'll get back in touch with you guys when I return home. As you can imagine, I'd like be sure I take care of the machine. Appreciate your patience.
Old 07-24-2013, 11:48 PM
Get a copy of NAVTRA 14217 and 14218.. google them. They cover the Singer 111W and a few others.. yours looks like a 111 clone. The NAVTRAs are quite good, the images/figures are very useable.
I learned to time and adjust the hook by simply making my 111W155 look like the pictures in the books.
finally buying a sewing machine PUREAUDIO Interior 49 11-08-2014 07:51 AM
What Sewing Machine? lbell101 Interior 6 01-20-2012 07:20 AM
sewing machine panelmanruss Interior 7 07-11-2010 08:41 AM
used sewing machine rodrieguz Interior 1 02-12-2010 06:56 AM
Sewing machine FiLkY tha FELON Interior 9 05-15-2006 12:02 PM
