finally a motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2002, 01:05 PM
New Member
Post finally a motor
Ok Guys and Gals I just purchased my first engine and I want some opinions. First it is a 350 out of an 88 chevy 1500. It is Tbi. It ran real good and tonight I go pull it. Its coming with a 700r4 as well. The questions are: Do I have to have the computer to run the tbi if so can i buy the whole computer plus harness cheap somewhere? I can run it with a carb but is there other things I have to replace as well? I have heard I need a fuel pump? I plan on dropping it right into my 54 chevy so y'all wish me luck.
Old 09-12-2002, 01:08 PM
Post
A friend of mine took a 350 from an '87 pick-up and put it in an '84 without any problems. He had to get a fuel pump for the higher pressure and took the wiring harness from the '87 and installed evrything in the '84.
You can use a different intake and use a carb if you wanted.
[ September 12, 2002: Message edited by: MHenricks ]</p>
Old 09-14-2002, 09:05 AM
New Member
Post
I didnt get the wiring from the donor truck so I think I will go with the carb and new air air intake. Will this give me more power for cheaper than purchasing a new computer and harness?
Old 09-14-2002, 11:20 AM
aka Duke of URL
Thumbs up
Yes.
Old 09-15-2002, 09:26 AM
New Member
Question
what should i go with carbwise? how about the intake.????????????????/
Old 09-15-2002, 04:43 PM
slider in wa's Avatar
Slider in Wa.
Post
If this is a styock motor &lt; i don`t think you can go wrong with eldbrock intake with a elbrock 600cfm carb.I am sure happy with mine.
Slider in Wa.
