Finally tuned and ready - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Off-Topic
Old 06-02-2011, 07:08 AM
Greg T's Avatar
www.krusinklassics.net
Finally tuned and ready- pics inside
Finally tuned and ready for dyno runs at our annual Fun Run in Escanaba this weekend!
ID:	55739   Click image for larger version
ID:	55740   Click image for larger version
ID:	55741   Click image for larger version
Old 06-03-2011, 06:06 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If it runs as good as it looks It show does look good.
Cole
Old 06-03-2011, 10:32 PM
Greg T's Avatar
Thanx Cole. It just wasn't my day. I exploded my distributer. Parts became pissed at one another and parted ways at about 5k. When I finally found a new MSD cap, rotor and wires, I found that my number one cylinder was not pointing at the right fender. What do you think the probable cause is? Twisted oil pump shaft or twisted dist shaft?
Old 06-04-2011, 12:06 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've sheared the cam gear roll pin before, something to look at.
What do you mean #1 not pointing at the right fender? You mean passenger side fender?
Semper Fi
Old 06-04-2011, 11:40 AM
eloc431962's Avatar
Wiki Edits: 37
X2 this could very well be your problem and a good place to start.
Cole
Old 06-04-2011, 11:04 PM
Greg T's Avatar
When I( orginally set the ignition up I set number one to be the left tower behind the carb. After the distributer exploded I put all now cap, rotor and wires on. Didn't run. Set TDC on #1 cylinder and looked at the rotor. Now it points at the passenger side fender. It's like 45* off. So, I started there and ran my firing order around and it fired right up. The advance curve is way out of whack tho. So I ordered a brand new E Curve dist from Summit.
Old 06-10-2011, 07:54 AM
Greg T's Avatar
Update
MSD's E-curve is the sweetest dist ever. I should have been using these from the minute they were released. Lock them out, set your max advance, and that never changes. You can dial in your desired curve without ever disturbing your max advance. Recurving takes about 3 minutes and you don't have to use a timing light, or even start the engine. I am very very pleased.
1930u- Finally ready for the drivetrain 1930u General Rodding Tech 6 11-27-2010 04:05 PM
Finally ready for winter..... Centerline Hotrodders' Lounge 5 10-29-2010 05:34 PM
Got it running and tuned, tell me what you think 41willys Hotrodders' Lounge 8 07-21-2008 08:31 PM
de tuned chevy350 Engine 13 11-19-2003 06:55 PM
how to tell if carbs tuned? Trav Engine 26 10-16-2003 01:01 AM
