FINALLY - A use for junk Chinese sockets - temp. coil spring boosters! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-22-2011, 10:16 AM
deadbodyman's Avatar
Wiki Edits: 11
Like this????
I'm going to make a guess that what you have is camero control arms on your monty frame that would explain the wider control arms....I cant tell you why
The camero has an 11" rotor but a 95 caprice and Impala are interchangeable and have a 12" rotor but you have to use the caprice spindle and ball joint with the control arm ....one more thing ,the GM also has a metric version with the 11" rotor thats a bit different it has a smaller caliper than the regular one and a different track width...
  #17 (permalink)
Old 09-22-2011, 10:52 AM
41SUPERCOUPE's Avatar
<Coupe there it is!
Last journal entry: 41 Chevy Special Deluxe Coupe
yeah like that, from underneath it looks like a sandpail.....yeah i'm toast, but i smile alot : )
  #18 (permalink)
Old 09-22-2011, 11:02 AM
<Coupe there it is!
I just cranked in some 1.5" coil spacers and took her for a spin, no rubbage!!
Gotta perma grin now!!
So I should pop the springs out and get some used uncuts?.....would the be Monty springs?
  #19 (permalink)
Old 09-22-2011, 12:41 PM
Wiki Edits: 11
I would start there ,if they dont work try some from a 80ish camaro...But have someone check out those upper control arms ,they worry me the way they're mounted.
  #20 (permalink)
Old 09-24-2011, 03:37 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
to me they look just like this http://gbodyforum.com/viewtopic.php?p=139065 this is an 87 monte there are great pics of upper and lower.
  #21 (permalink)
Old 09-24-2011, 05:39 PM
<Coupe there it is!
They sure do Helrazr.....maybe the guy meant 87, not 78.....heck I've dun that once or twice....lol
Here are a couple pics, was pretty soggy out there today so I only took a couple....sux no garage
ID:	58561   Click image for larger version
  #22 (permalink)
Old 09-25-2011, 07:08 AM
Wiki Edits: 11
Thats a much better pic and they look like they're mounted just fine.
  #23 (permalink)
Old 09-25-2011, 08:33 AM
<Coupe there it is!
Cool, did u see all the shims?.....by adding or removing them, what does that accomplish?.....just wondering
  #24 (permalink)
Old 09-25-2011, 09:13 AM
helrazr3's Avatar
the shims are for the alignment its not unusual to see a few on either side thats how they set the caster and camber to lean the tire in and out from the top
  #25 (permalink)
Old 09-25-2011, 09:33 AM
<Coupe there it is!
Gotcha, castor/camber.....I fingered they were for alignment.
Hows things in the Beantown area?......grew up in Luneyburg/Princeton myself, then moved up into the woods "Maine" when I got outta HS to get away from all them Mass-holes.....Hey wait a sec., I are one
coil spring spacers APalusky Suspension - Brakes - Steering 19 10-01-2010 02:20 PM
Spring is FINALLY here! Blazin72 Off-Topic 7 05-18-2008 12:48 PM
Coil spring for 350 on a S10 GMC1950 Suspension - Brakes - Steering 5 02-29-2008 10:29 AM
Spring break is finally here, but....... onebadmerc Hotrodders' Lounge 3 03-18-2005 08:26 AM
If I cut a coil spring Bluepen Suspension - Brakes - Steering 2 06-01-2004 06:06 AM
