Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Finaly a bad review on the Harbor Freight Purple Gun
Old 05-21-2012, 04:30 AM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
Originally Posted by mitmaks
Don't be ignorant and just dump paint right into gun and start painting. First you must rinse it out with solvent. I've used this exact gun at work with no problems, for $10 you can't say it's a bad gun.
That's not what happened to me. I ran about half a cup of lacquer thinner through the gun before I ever used it. It worked fine for about the first 5 uses and after use cleanings (spraying solvent trough and cleaning the cup), THEN THE STUFF INSIDE TURNED TO GOO AND MIXED IN WITH THE PAINT.
Give me a small amount of credit here...
Andy
