Finding 3links in unexpected places - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2009, 06:25 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
As I was preparing a new 3link spreadsheet for my site (Page 40), I realized that it could also be used with triangulated 4link and torque arm suspensions. While neither of these are normally considered 3links, if you think of the triangulated pair in a triangulated 4link as a single centrally located link and if you think of a torque arm as being the extended mount for a link having zero length, you end up with...as far as the spreadsheet is concerned...a 3link.
The spreadsheet then tells you how to adjust the angles of the remaining links so that the driveshaft torque is dynamically cancelled. In other words, for any value of driveshaft torque, the rear tires remain equally loaded. (This is assuming, of course, that they were equally loaded before the launch.)
This means the fronts lift equally, no preloading is necessary, and the car leaves straight every time.
http://www.racetec.cc/shope
Old 08-21-2009, 11:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Now THAT'S a site w/suspension info!!!
On another thread we were just mentioning that suspension work might have been part of what "High and Mighty" was about, research-wise.
Old 08-21-2009, 11:38 AM
dont know if this helps any but if u need a 3 link i believe ford aerostar vans came factory with them
Old 08-21-2009, 01:09 PM
BillyShope's Avatar
Philippines Cowboy
And Crown Vics. And, of course, late Mustangs. I believe the Mustang is the only one with a very short odd link, but I could be wrong. Could be sources for brackets and links, certainly, though most any coil spring car would serve the same purpose.
Old 08-21-2009, 01:14 PM
in my area i have seen several aerostars in average condition for round 3-500 good for the budget builder.
that site has tons of info good find
help finding this gear gilby246 Engine 6 03-11-2008 08:02 AM
E-coating advantages, disadvantages, and places Jamescoop Body - Exterior 1 03-08-2005 04:00 PM
finding project cars wannabnewbie Hotrodding Basics 25 11-12-2004 05:10 PM
