Finding a bad ground - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2012, 09:45 PM
Javelin360's Avatar
Deviant AMC Guy
Last journal entry: Hauling it home from Dixie.
Recently I noticed that when I turn the headlights on in my 74 Javelin the left blinker light illuminates. It has been intermittent. I'm thinking I've a ground in the column but I have no idea how to find it. Any suggestions?
Old 09-23-2012, 06:31 AM
SSedan64's Avatar
I had a similar problem with my Chevy 71 C10, right blinker indicator in dash would lite up when I switched the Headlights on. The blinker mount bracket on the bumper was loose causing a bad ground.
The Following User Says Thank You to SSedan64 For This Useful Post:
Javelin360 (09-23-2012)
Old 09-23-2012, 06:59 AM
poncho62's Avatar
Wiki Edits: 5
I would start by checking the ground at that left blinker light and go from there. In an older car, I would go around and clean all your grounding points.
The Following User Says Thank You to poncho62 For This Useful Post:
Old 09-23-2012, 08:19 AM
Javelin360's Avatar
Deviant AMC Guy
Thanks for the replies. I look at the mentioned areas today.
Old 09-23-2012, 05:03 PM
Javelin360's Avatar
Deviant AMC Guy
Checked the bulbs and they were good. Checked the ground in the trunk and it was good. Noticed some corrosion on the front blinker housing prongs. Used a bit of emery cloth and cleaned them up. Magically everything works correctly now.
Thanks folks.
Old 09-24-2012, 03:58 AM
EOD Guy's Avatar
Good to hear you got it fixed, alot of folks don't post back with results.
How bad will a 4-bar suspension be with lower bars not parallel to the ground? jamieson Suspension - Brakes - Steering 4 05-03-2012 05:54 PM
1981 Camaro, bad starter ground?? lizardking7750 Electrical 8 02-23-2010 07:44 PM
Bad ground? dean7276 Electrical 7 09-16-2007 09:08 AM
Ground cable bad? tomthecomic Electrical 8 08-07-2007 02:51 PM
