finding cam specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2002, 07:27 AM
beetle9's Avatar
Question finding cam specs
I recently acquired a new cam for a sbc. I know little or nothing about it other than it is a high performance cam as the paperwork and cam card were lost. If I can mic the lobes and find out the specs would that help or wouldn't that tell me anything?
Old 12-01-2002, 09:13 AM
BOBCRMAN@aol.com's Avatar
Post
what are the numbers stamped in the end of the cam?
Old 12-01-2002, 09:15 AM
Frisco's Avatar
Glad To Be Here
Post
Mike across the highest and lowest point on one of the lobes. Next mike across the lobe 90 degrees from the previous point. Subtract the smaller number from the larger to get the lift at the cam. For total valve lift, multiply the cam lift by the rocker arm ratio (usually 1.5 for Chevy small block) to get the total lift at the valve. Do this for both the intake and the exhaust. This will not give you the duration though. If you know the cam manufacturer you can check the cam # found on the end of the cam to get the specs.
[ December 01, 2002: Message edited by: Frisco ]</p>
Old 12-02-2002, 06:22 PM
Post
Hey dude,
You can get the tool to do the job from summit racing equipment. it's got a dial indicator on it and it mount to the block with the cylinder head off, you can measure lift and duration with it so don't worry, if all else failed and simple dial indicator,and a cam degree wheel would do the job.
keep on roddin' <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
Old 12-03-2002, 05:42 AM
beetle9's Avatar
Post
mystery solved-This is a factory 300HP cam that came in some 327s. I had a 64 impala ss with one. Not a race came, but it was high performance. I don't think I'll use it in my street rod, but I have a GMC pick up I use to tow my RV with. I plan to add headaers this summer and might throw this cam in at the same time. Any opinions?
Old 07-08-2009, 11:02 AM
"929"
I guess this to be old news but it was hard to beat the ole 929 300Hp 327 L48 Cam(3896929) not high performance but a performance cam none the less just below the 151 L79 cam 350Hp 327 cam these are oldies but they will still wake up a sbc. with out robbing the bank. Stan
Old 07-08-2009, 02:02 PM
fast68's Avatar
likes chevy trucks & boobies
dude this post is 7 years old ***
and besides, there are tons of current camshaft threads already. too many..
good luck
Old 07-08-2009, 11:22 PM
old stuff
Yeh, I kinda figuared it was dated but didnt know it was that old, oh well old cams are like old Chevys you cant killem just use a little more duct tape the handy mans secret weapon.trucks are great Lefty
Old 07-09-2009, 01:18 AM
techinspector1's Avatar
Wiki Edits: 326
If it moves and shouldn't....Duct Tape.
If it doesn't move and should....WD40.
That's all you need to know.
