finding correct coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2008, 10:19 PM
I need to know how to pick the correct coil for an engine. Do you check ohmage, resistance, or what. The enjine has a cdi box called an igniter unit, with pick-ups on flywheel. It runs two coils, one per cyclinder and is a 12 volt system. Each coil has 2 wires going to it with a lead to a spark plug. And it is a two cyclinder motor. This is a running engine, what I want to do ,because the coils are so prominent, is to make a presentation out of them. Two nice chrome units with colored wires etc,etc. SO how do I pick the coils??
Old 11-29-2008, 09:47 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
So....what kind of engine is this? What brand name etc. It sounds very similar to the ignition system on some outboard boat motors.
Old 11-29-2008, 01:42 PM
coils
Henery, Thanks for your interest. The motor in question is a yamaha, around 1986 and is mounted in a hom-built airplane. I have been told its a Virago engine.Thanks again
Old 11-29-2008, 01:46 PM
Lost in the 60's
Wiki Edits: 4
You should be able to get the coils from a Yamaha dealer then.
Old 11-29-2008, 02:47 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
I would write down all the information off the engine name plate that you can (atleast model and serial #) the dealer should be able to match you up with the right ones that way.
testing a coil bentwings Electrical 1 09-02-2008 09:22 AM
Question about hooking a msd blaster coil to a msd dizzy tiresmoke55 Engine 4 04-29-2008 03:41 PM
Push botton starter street rodder 1937 Electrical 4 03-17-2005 09:19 AM
SB Chevy Ignition coil resistor frackster66 Electrical 5 11-26-2003 10:03 AM
No Spark at Coil/ 350 SBC 1966impala Electrical 4 10-01-2003 12:07 PM
