Finding my govenor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2003, 01:28 PM
Dreadlord's Avatar
Proficient Motorsports - Owner
Last journal entry: The Trucks Redemption
Finding my govenor
i have a 91 camaro rs and i was trying to find where my govenor was located. could anyone help.
Old 11-27-2003, 02:19 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
He's in the Governors Mansion!!! LOL!!!
Kevin
Old 11-27-2003, 05:53 PM
adtkart@aol.com
Would help if we knew what state you are from.
Old 11-27-2003, 05:56 PM
Dreadlord's Avatar
LOL okok the isnt there a speed restrictor in my car that wont let it go over a certain speed. can you help me figure out where it is at.
Old 11-27-2003, 06:22 PM
Kevin45's Avatar
Not certain but I believe you have to change the chip in the computer or have it reprogrammed by using the Hypertech programmer.
Kevin
Old 11-27-2003, 06:23 PM
dreadlord,
The governor is in the tail shaft housing of the transmission, but it doesn't keep the car from going too fast, it just causes the transmission to shift when engine reaches a "given" RPM. By doing so the engine will not over rev and you will not end up walking home from the drag strip.
You can override this in cars with manual/automatic valve bodies by putting the selector in "low" and giving it the gas. The car will stay in that gear until you move the selector up to the next gear. If you do not move the selector the engine will keep revving up until something gives. In the end it is usually your checking account that gives the most. Either by paying ticket or shop owner for services rendered.
Be Safe
Scholman
Old 12-02-2003, 11:33 AM
Guy with the small engine
yep, that's the way to deal with the rev limiter. the governor is a little different; either a reprog will need to be done on the ecu, or you'll have to hook up the wire that goes from the speed sensor on the tranny to the ecu to a switch - turn off the switch and it kills the sensor signal to the ecu. this get's around the speed limiter, however it'll kill the odometer and speedometer. keep in mind this can only be done on a manual tranny.
Old 12-02-2003, 02:27 PM
Dreadlord's Avatar
ook thanks but just out of curiosity my cousin has a 96 camaro and his govenor/speed limiter was bolted on teh engine. why would that be? and could mine also or not
Old 12-02-2003, 02:35 PM
daimon1054's Avatar
Gas engines donít use a governor diesels do though.
In í91 the Camaro came with 2 tires 1 was Z-rated and there was no speed limiter the other came with H-rated I think. Those cars had a 120 mph limiter; the computer is what cuts fuel when you get to that speed. Any aftermarket chip will eliminate the speed limiter.
