finding the right cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2010, 02:34 PM
I have a 84monte carloss with a sbc377 its 12to1.with a 64cc dart227 i need to find the right cam.my heads max out at 700.thanks
Old 03-28-2010, 07:04 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You can contact, http://www.cammotion.com/ .Or http://www.bulletcams.com/ . They can grind you a cam for your engine just give them all the specs.
Cole
Old 03-29-2010, 12:29 AM
Bad Influence Racing's Avatar
Engine Builder/Head Porter
I will assume the rpm range you are looking for is kind of high, above 7,500 with that big of a cylinder head on a small engine. Fill me in on the rest of the combination as well as the setup on the car, gear, tire, converter,trans,weight... I would be careful calling most cam companies for their uneducated guess at what it would need, you will go nowhere fast. Stick with a builder who has done what you are trying to do for better results.
Kris
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 11:03 AM
I need cam help 355s10 Engine 5 03-16-2008 05:34 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
Oddball Cam source? Biggarmike Engine 3 02-02-2003 10:52 AM
