Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Finding A short?
Old 05-01-2013, 10:08 PM
evolvo's Avatar
evolvo evolvo is offline
With your meter hooked up as you described you can pull one fuse at a time from the panel and observe what the voltage does. If you pull the fuse for the window switches and the voltage stays high you have a draw somewhere else. BTW, my window switches only light when the park/headlight switch is on. 10.6 V is way to much draw with the key off.
