Finding TDC on SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2012, 11:11 PM
Finding TDC on SBC
I had to change my balancer on my 350, the balancer i'm using is for a 12 O'clock Timing tab so i can't use the line on the balancer since my timing tab is at 2 O'clock, what's the best way to find TDC, do i look at the Valves? i don't want to use a piston stop since i'm worried i can bend a valve
Old 10-21-2012, 11:13 PM
DoubleVision's Avatar
Why not replace it with the correct balancer? As once you find TDC how are you going to set the timing?
use a stop you not going to bend a valve
Old 10-21-2012, 11:19 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.crankshaftcoalition.com/w...op_dead_center
Follow these instructions, you won't bend any valves.
Old 10-22-2012, 03:29 AM
Finding TDC on a SBC
Check at Advance Auto for a direct replacement. The prices are not that bad and you would avoid a lot of future headache. Buy Dorman - OE Solutions Harmonic Balancer 594-009 at Advance Auto Parts
Finding TDC bl8ton Hotrodding Basics 2 12-31-2011 09:18 AM
Need help with finding TDC Infinite Monkeys Engine 14 12-27-2011 10:27 AM
Chevy SBC, finding TDC without timing marks 04SilveradoMykk Engine 2 10-25-2009 06:11 PM
finding TDC on #1 Chuck Q Electrical 9 04-26-2007 05:37 AM
Finding TDC ryanf Engine 9 04-22-2004 09:20 PM
