finding wheel that fit my bolt pattern - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-24-2013, 06:43 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by Dayo5 View Post
According to the VIN it is a GT-37
Your serial # should ba 233370 a or p 1xxxxxxx1 ,the first 2 means pontiac division of gm next 33 is body style T37 the 37 means 2 dr ht 0 yr 1970 1xxxxx1 production # trere were only 1413 produced in 1970 so you have a rare car if is a pillow post car it will have a different # even more rare ut is a version like the 300 series Chevelle ,it was designed as a light weight low cost car to compete with Roadrunner and Superbee it will have a 400 Only engine offered,a overhead cam 6 a 326 ,350 and 400 were offered in a lemans ,same car just up scale 70 t37 were tempest 71 were lemans or tempest depending on if it was a hardtop or post ,this car has value,check it out,If tou want i will decode it for yor list First part of data plate DO NOT list serial #on here,uf early 70 data plate will be in windsheild later 70 is on firewall above brake boosterm Hope this helps
  #17 (permalink)
Old 01-31-2013, 09:43 AM
month ago i was looking for parts in a salvage yard in south dakota. found a T37 hadn't seen one in 30 years
S10 rear will fit but wrong bolt pattern Rmvr53 Transmission - Rearend 14 09-24-2011 06:59 PM
Front Wheel Bolt Pattern? texastomeh Suspension - Brakes - Steering 4 08-03-2006 09:14 AM
6 lug chev bolt pattern, what else will it fit? tiresmoke55 General Rodding Tech 2 01-23-2006 05:56 AM
Looking wheel bolt pattern info Huskinhano Suspension - Brakes - Steering 5 01-19-2005 05:17 PM
Bronco wheel bolt pattern? Seon General Rodding Tech 2 05-15-2003 04:39 PM
