In a word....yes.
Wheel sizing - Wikipedia, the free encyclopedia Pay particular attention to "centerbore". Matching this will take the radial load off the studs/nuts. |
Also, your RWD car wants wheels with as close to zero offset as possible. That means you cannot use the FWD wheels that have a large positive offset. Offset is the measurement of how far the wheel mounting surface is "offset" from the centerline of the rim. Zero offset means that they are lined up. Positive offset means that the rim (and tire) centerline is further inboard than the wheel mounting surface, negative offset means that it is outboard. Unfortunately, most wheel vendors specify backspacing instead of offset, and that's not really useful without also knowing the wheel width and the additional flange thickness on the edges of the rim. |
Good luck. |
Go to most tire stores pick up a progressive wheel handbook ,it will list bolt circle back spacing and center diameter for about all vehicles a big help , a T 37 Temrest a rare find your lucky, is it a t37 or gt 37
Every GM RWD intermediate (Chevelle, LeMans, Cutlass, Skylark) built from 1964 to 1988 used the 5 x 4.75 pattern.
wrong center bore
My son used a mustang steel spare wheel for his spare on a Lincoln Versailles 9 in rear. He went from N Calif bay area to LA, with the mustang wheel, He was " too busy" to get the correct aluminum wheel flat fixed. Some where in the middle of an LA freeway the wheel started to wobble. IT had several cracks. Lucky, the traffic jam had traffic only going 25 mph.
Nice find. Not to disillusion you but it would prollably be more accurate to call your '70 a GT-37/Tempest. One main reason for its existence was to not be as "sporty" as the GTO (bench seats, stripped down) so it could be insured cheaper. That actually made it quicker than a lot of GTOs, though.
That's great! I would go a step further and call it a Frankenstein GTO/37...someone really hacked into it at some point wanting a GTO- they put on the GTO Hood, Endura front bumper, rear wing, and full GTO interior with buckets. I am still trying to figure out the engine, I am having a hard time finding the stamp on the block, I did find an "XS"...it has an edlebrock manifold into a rochester carb.
XS was used a lot. From a 301, 350, 389 and 400 in various years.
Links for ID'ing your engine can be seen at Pontiac engine info. You might also want to take a look at Pontiac info/sites. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
Dayo5 (01-24-2013) | ||
mustang wheel.
the 9 in disc rear was out of a mid 70's. versailles. the mustamg center hole was a little bit smaller, but the bolt pattern was the same.the wheel lug area did not fit tight to the rotor.
| S10 rear will fit but wrong bolt pattern | Rmvr53 | Transmission - Rearend | 14 | 09-24-2011 06:59 PM |
| Front Wheel Bolt Pattern? | texastomeh | Suspension - Brakes - Steering | 4 | 08-03-2006 09:14 AM |
| 6 lug chev bolt pattern, what else will it fit? | tiresmoke55 | General Rodding Tech | 2 | 01-23-2006 05:56 AM |
| Looking wheel bolt pattern info | Huskinhano | Suspension - Brakes - Steering | 5 | 01-19-2005 05:17 PM |
| Bronco wheel bolt pattern? | Seon | General Rodding Tech | 2 | 05-15-2003 04:39 PM |
