Fine tune my SBC 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2011, 02:26 PM
Madmax305's Avatar
My 67 El Camino is running pretty good. I want to fine tune the car now...It has 350 engine, 9-1 compression, RHS vortec 64cc heads, headers, HEI, Comp magnum 286h cam, TH350 with 3000 stall, 4.10 gears, Holley 670 carb, etc...
My vacuum gauge shows 9" of vacuum with car in drive, at idle. The plugs show a little lean. I was thinking of changing the power valve from 6.5 (stock) to 4.5 and change the 65 (stock) primary jets to 67 for starters. The initial timing is set to 24 degrees with 700 rpm's in drive. Any thoughts or suggestions....
Old 09-29-2011, 02:55 PM
techinspector1's Avatar
Wiki Edits: 326
The motor may be a little soggy because of the mis-match of compression ratio and camshaft timing. The cam you're using has an intake duration of 236 degrees, while the static compression ratio is calling for a cam with an intake duration of around 204 degrees.
http://www.crankshaftcoalition.com/w..._compatibility
Do a compression test to see what you have for cylinder pressure.
1. Fire the motor and bring the coolant up to operating temp.
2. Disable the ignition system so that you don't have a fire in the engine compartment.
3. Remove all spark plugs so the starter can turn the crank easily.
4. Wire the carburetor primary throttle blades wide open so that the motor can breathe.
5. Turn the motor through 4 or 5 "chuffs" on each cylinder to make sure you have maxed the gauge each time.
Your change of power valve agrees with info from Holley....
http://www.holley.com/data/TechServi...wer_valves.pdf
Old 09-29-2011, 03:39 PM
Madmax305's Avatar
Good points. At some time in the future, I plan on switching out to a more agressive short block. Keep the suggestions coming guys...
Grit - how fine is too fine for adhesion? cboy Body - Exterior 41 06-28-2009 05:20 PM
skills to fine tune HEtkind Introduce Yourself 2 01-12-2006 06:31 PM
doing fine in 69 gary monks Introduce Yourself 3 01-07-2006 07:47 PM
Fine Tuning waitingpeace Introduce Yourself 6 12-01-2004 07:47 PM
First TH350 OH is in and doing fine! Jmark Transmission - Rearend 0 03-13-2004 10:22 PM
