Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 07-01-2008, 04:52 PM
jimmy1 jimmy1 is offline
Fineline Tape question?
I painted the top and sunvisior for my 51' GMC this week end and I'am going to mask it out at the belt moulding up so I can start the second color next week and my question is, I'am using the 3m fineline at the edge and was worried about the time it might have to sit there on fresh urethane until I can get back to it.
Old 07-01-2008, 07:31 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Moderator
re: Fineline Tape question?
That time span should be no problem as long as the vehicle has been indoors.
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Old 07-03-2008, 12:17 AM
BMM BMM is online now
I had some 3m fineline on paint after it had been sprayed and baked for a day. I left the tape on for the weekend, and it was fine. No residue or anything.
Old 07-04-2008, 07:56 AM
Fineline tape question?
Thanks Guys!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Fineline Tape question?"
383 stroker 73monte Engine 9 04-28-2008 02:34 AM
question on tape to weather strip? FRANKBULLITT Body - Exterior 2 01-15-2008 04:50 PM
supercharger.... 73monte Engine 10 07-31-2006 09:38 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
