Finish Tuning
Having some issues with a new setup. SBC, flat tops, 882 heads, ~9:1, 500 lift/300dur, lo-rise intake, Holley 650 carb. Plenty of fire, all MSD. Engine seams to be running rich , can't get that clean crisp strong idle. Sluggish from a start like its loading up and also at cruising speeds with throttle just cracked. Runs decent when I get on it. A little help please?!?!
This is just a guess, because I'm certainly no carb guru. The long duration of the cam is causing low manifold vacuum. The power valve is seeing the low vacuum and mis-interpreting it as the motor being under load, opening up the circuit and adding fuel. Maybe you could install the lowest calibration power valve (1" hg) and try it.
http://www.jegs.com/webapp/wcs/store...-1&showValue=1 |
where are you mixture screws at, you may need to reduce the diameter of the IFR's
Assuming your timing is all where it should be, the next thing to do is put a vacuum gauge on it. Measure manifold vacuum off the carb or manifold. As mentioned already, make sure your powervalve isn't open at normal cruise or idle vacuum. Set your idle to maximum vacuum. That should be a starting point.
How do you know it's rich and not lean off a start? Oh, thought of another early thing to check: make sure the float level isn't too high and dumping excess fuel into the venturis. A 02 will make things a lot easier. |
In you scenario the pv will be open at all times, but it will not feed fuel to the idle circuit. |
If it's open at idle and feeding fuel into the motor, then the idle circuit has nothing to do with it. The motor will be rich regardless and you won't be able to get a clean idle. That was where I was coming from.
" i thought you were saying that an improper powervalve would give you an overly rich idle." Yes it will, just won't be through the idle circuit. Forget the idle circuit. That's not where the problem is the way I see it. |
After your responces and reading some of the other threads I relly believe there is a Vacuum issue for starters. I also believe that the "match" of the components is wrong. 82 350 4bolt .040 over w/ eagle crank and rods, hyp flat tops 882 heads 1.94/1.50 valves 160? cc runners 76cc chamber basicly stock Crane 100112 cam 500 lift 302 adv dur Wiend intake http://www.holley.com/8004.asp Holley 650 DP vac advance All parts are new or rebuilt I am looking for a decent set of aluminum heads with ~64cc chambers and bigger runners and a more aggressive intake. Should bring it to life. Thank you very much for all your help guys!! Take a look please...... http://s279.photobucket.com/albums/k...t=e9853e33.pbr |
Have a set 461 castings, yes the old double humps...again! lol that I can pick up from an older gentleman that came out of a mid 60s 327 vette orig. Been sitting in his shed for 20 yrs. 100 bucks plus shipping yes 2.02s
http://i279.photobucket.com/albums/k...ls/7ff5_12.jpg or something loke this: http://i279.photobucket.com/albums/k...s/23ab_1-1.jpg New set of Aluminim Small Block Chevy Pro Comp Motorsport Heads (2 heads) Produce 500 HP Out Of Box With Advanced Port Design Just do a nice bowl blend 210cc Intake Runners 64cc Chambers Straight Plug Design for easy header clearance (ANGLE PLUG AVAILABLE ON REQUEST FOR SAME PRICE) Bronze Valve Guides Premium Hardened Seats 2.02 and 1.60 valve seat size for 420 bucks bare economy went to hell so $$$ is tight now, unless Im going to get 50+ more hp off the alum heads screw it I'll be a camel jockey. :spank: sorry if I offended anyone. |
to the original poster. Your combo is fine it just needs some tuning to run properly. How much vacuum are you getting at idle? Where are your idle mixture screws set at? Did you set your transition slots in the carb properly? |
One of the local shops recommended that I block off the power valve and increase the primary jet size by 2-3. Also, not running any vac lines off the carb at all. No PCV at all just vents, and the brakes and trans is off the intake with a T. Whats your take on this?
Steve |
I agree, DO NOT block off your powervalve. In fact, don't go back to the shop that recommended this to you. Anybody who would recommend that for a street car has no business tuning carbs. It's not terribly difficult to do things the correct way. With a little knowledge and some trial and error you can tune the carb to work perfectly.
The only time to consider losing the powervalve would be for a race only engine that is only WOT or idle. |
Oh, forgot to add. You need a pcv to have some negative pressure in the crankcase. This will help the rings stay seated which helps power and efficiency.
| All times are GMT -6. The time now is 09:30 PM. |
