Finishing off Year One 350/400hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2010, 05:01 PM
Hi, I purchased the year one 350 with 400hp http://www.yearone.com/serverfiles/f...ngine&SM=1&SC=. I should be recieving it within about 2 weeks. I have called the shop numerous times to ask about which parts are needed, and I always think of more questions once I am off of the phone. So I know everyone here could help me out. I am not sure if a Fuel Pushrod will already be in this block. If anyone knows let me know. Also because it has a Hydraulic Roller Cam, would a bronze tip comp cam pushrod be ok so it doesnt grind. Also wondering if anyone knows if these heads are square port or round port so I know which copper gaskets to buy for my headers?
Next that brings me to the starter and fuel pump. Would you go with a high torque starter that costs 150, or could I get away with a remanufactured OEM starter for 50 bucks? I was also looking at a holley fuel pump that is 110gph, http://www.summitracing.com/parts/HLY-12-327-11/, is this a good pump for the engine. Last question I have is regarding motor mounts, can I just use the polyeurathane motor mounts and tranny mounts that run about 9 dollars a piece from Auto Zone, or should I buy the ones from summit that are 73 for the entire kit? Thanks for your help guys. It has been 11 years since I have driven a classic car, so I want to have everything ready to go to get it running same day .
Old 06-02-2010, 06:15 PM
techinspector1's Avatar
Wiki Edits: 326
A couple of things here....don't know what intake manifold the motor will be shipped with, but any of these 3, depending on the finish you desire, would be my choice.
Performer RPM Vortec #7116*
Performer RPM Vortec w/ EnduraShine finish #71164*
Polished Performer RPM Vortec #71161*
As far as a fuel pump, if I were going to use a mechanical and didn't want to fool with a regulator, this might be my choice.
http://www.summitracing.com/parts/CRT-M6624/
Excellent volume with reasonable pressure to prevent overpowering the needle and seat in the carb. The Holley you're looking at has too much pressure unless you planned to include a regulator. No reason to go to all that trouble, just use the correct pump in the first place.
Old 06-02-2010, 06:54 PM
Hi Tech, Thanks for being so great with your replies. I will purchase that fuel pump. They are including a dual plane intake already, so I wasnt really planning on having to change it at all. Is there a reason why I would have to change it? Car will never see the strip, just being a good cruiser.
Tech if I could bother you to answer a couple more questions. I will list them to make it easier.
1. What starter would you use?
2. Do you know if the vortec heads are square/round ports?
3. What mounts would you use for this engine and th350?
4. Would a bronze tipped pushrod be ok for a hydraulic roller cam and do you possibly know if there will already be one in place?
And Tech, I want to thank you immensely for all of your help this past year. You have always been there to answer my questions. Thanks again, Peter
Old 06-02-2010, 07:38 PM
Wiki Edits: 326
Lifetime starter at Autozone. Hold onto the receipt.
Order exhaust gaskets for '98 Chevy 2500 series truck with 5700 Vortec motor, RPO L31.
Stock Chevrolet, across the counter at your local Chevy dealer. I don't care for that poly junk.
Doubt there will be one there. Find out who the cam grinder is and call their tech line for a recommendation.
Appreciate your vote of confidence.
Old 06-02-2010, 08:08 PM
Thanks again Tech. My uncle used to always help me out with these things but he has since passed away. I just needed a car, if only to walk into the garage and smell that carbureted smell. Just brings back so many memories. Thanks for the advice, it is greatly appreciated.
On a side note, I brought that copper/brass radiator today to a local rad shop, cost me 30 bucks and they said it should be good as new. They attached a trans cooler they had laying around to the radiator for 10 dollars. Cant beat cooling for 40 bucks when I was looking at 485. Thanks for the advice. Now on to finding a thermostatic clutch, water pump and I have to measure the opening for the shroud to ensure that 18' 7 fan blade will fit. Thanks Peter
Old 06-02-2010, 08:42 PM
Hey Tech, I am guessing I am looking at way overpriced water pumps at summit, is there one in particular you would go with?
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 08:47 PM
"Basics of Basics" Molding repair / metal finishing MARTINSR Body - Exterior 6 07-09-2009 09:47 AM
Metal Finishing, to quote the great philosopher NIKE, “Just do it”. MARTINSR Body - Exterior 17 12-24-2005 11:08 AM
What year is my GTO? schuffm Hotrodding Basics 5 10-29-2004 05:14 PM
Ford 390 rebuild...What's the best year?? Bo_Jangles Engine 3 03-01-2002 04:02 PM
