Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Finishing up BBC build quench and dynamic compression questions
Old 01-14-2013, 09:42 PM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Originally Posted by jumbo2 View Post
Well I got my dial indicator and stand today!!! a trip to the local vet and got some large and small syringes and a chunk of plexiglass from a friend to cc heads .
So after measuring how far down the pistons are in the block , ontop of the wrist pin on one side because of my piston head shape , I got .014 as the highest and .016 as the lowest
Next im going to cc the heads , should I grease the valves ?
Put the springs on and use trans fluid it is thick and wont leak any leak and you got to fix it and start over. 1 cc is very small and you are certainly looking to get that close a measure.
