using the Keith Black comp calculator i got 10.47:1 static , and using 59 deg is my intake closing point +15 deg I get 8.73 dynamic
using
Static/Dynamic Compression Ratio Calculator
I get static 10.48:1 dynamic 8.06:1 using what they asked for
using
Jeep Strokers • Dynamic\Static Compression Ratio Calculator
I get 10.36:1 static 7.95:1 dynamic and off my duration and LSA the program came up with a 70 deg closing point wich would explain why the diffrence
so what gives , what would you listen too ? most calculators I can find give me the same 10.5:1 and around 8:1 dynamic except the keith black but thats the only one that doesnt ask about the +4 ground into the cam from comp hmmmmmm maybe
