fire under hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2005, 05:51 PM
IROC100's Avatar
Running on empty
Last journal entry: More pics
fire under hood
I got my tilt system last week and finally, got it back on the truck, while I had the hood off I did some touch up. I would like some comments on the color of my flames that are on the inside of the hood, do you guys think the color is ok or should I go with a different color? This is just an experiment, I did some test pieces, but I wanted to see what they looked liked on the hood. If I keep this color thats what will go on the outside. I'm just looking for opinons.
Old 03-08-2005, 06:37 PM
segge's Avatar
I think they look good if you were to redo them I would say to go to a little lighter color to give it sortof a ghost flames type of look.
Old 03-08-2005, 07:27 PM
daimon1054's Avatar
Looks good to me as it is! I think ghost flames would get lost under the hood, you need light for them to show so I would think it would be a a waste under the hood because you will never get good light.
Old 03-08-2005, 08:49 PM
Color looks fine. May I suggest maybe a pinstripe outline around them? Something bright, orange,yellow,maybe lime green. Just a suggestion.
Old 03-09-2005, 07:42 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
You got a good idea/start.
Widen you base's some. Narrow your run's to the tips a little more,they are a little fat.
Try some "Devil Tails" on the tips.
You asked.
Old 03-11-2005, 04:41 PM
IROC100's Avatar
Running on empty
Thanks guys I was wondering about the color, I like it and usually don't care what other people think, but this was different , I just wasn't sure, but I think I will stay with it for my flames on the outside. again thanks.
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
