You could find a way but it probably wouldn't justify the cost and labor.
A few thing's you can do is, buy another hood if you can find one.
Buy an after market hood or, get a bolt on cowl to cover it up. I think the formula's dual ram snorkle hood looks awesome. If someone cut a hole in this original Formula hood they should be hung from a tree and flogged! If it doesn't have this hood, it isn't original anyway so I wouldn't bother and get an after market replacement. I doubt a patch would last very long and will eventually crack from the abuse of opening and closing all the time. JMO
im shure my hoods factory just with a 6inch hole in middle of it
when i got the car it was set up for a sb chevy an weired cable's to limit the down travel on the lower a arms. i put it back together with ra pont 400 an a 4speed
the hood has the functional dual scoops if i had the right filter housing. the hole in the middle of the hood is set back some from were the pont 400's carb is idk if they set the sb chevy closer to the firewall when i got it didn't have the motor or trans but the sb chevy mounts were there an welded to the crossmember wasn't fun getin those off
It is possible to weld a piece cut from a stock Firebird hood into the hole to repair it. will require good welding skills and bodywork, it would be best to take it to the best oldtime bodyman in your area and pay them to do it if you are serious about saving it.
Not the place you want a rookie or less experienced welder doing the welding, very easy to warp it and ruin it.
X2 couldn't agree more Eric. I had a buddy that had his challenger hood repaired and it looked good for a year or so and that's being nice because really you could notice where it was repaired at if you looked and didn't have to look hard either. There are some people out there that can do this and it will really look good but it might cost a bit. :thumbup:
Now that you mention it, I don't know . I know the '70-73 is, and the '77-81 is metal, but IDK about the '74-76 years. If it is fiberglass that makes it even easier to fix.
Fiberglass :thumbup: Just a matter of patching the hole, smoothing the work, priming and block sanding the entire hood and then Epoxy priming and painting. You could leave it in Epoxy primer if you want the flat black look.
It won't need to be re-gelcoated.
If you know how to worjk with fiberglass it is a piece of cake, your hood can be saved. Bodyshop or even a Marina(boats are fiberglass) could help you.
I want to keep my hood, but it limits what I can do to my engine... I've actually thought about cutting a hole, but I just can't bring myself to do it. My scoops aren't functional. I can honestly say that a fiberglass hood from a 70-75 Formula is the heaviest damn hood I've ever removed in my life. When I first found out mine was fiberglass, I was shocked! I wish mine was functional though...
the hood doesn't weight that much its just odd to handle with 1 person but ive not handled alot of these things i think my friends steel hood off his 76 first edition hurst t-top was alittle heavier
Yeah I just took one off the other day Im glad mine dont have one
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
